Rotate About Line
Rotate About Line
kdiver
Rotate About Line
kdiver
This seems so simple but I cannot figure out how to do it. I want to rotate an entire part 30 degrees. The front view. I go to modify and move bodies but do not see the "Rotate About Line " option that some people have suggested in an Internet search. I can move it with my space mouse and save the movement as new front view.
   I have Inventor Pro 2018. Where is it hiding?
Accepted solutions (3)
JDMather
You can do this either with Direct Edit or with Move Bodies (Rotate).
Attach your *.ipt file here if you can't figure it out.
johnsonshiue
Hi! The major difference between Direct Edit -> Move/Rotate and Move Bodies is that DE only handles solid bodies, while MB can take surface bodies and composite surfaces also.
Many thanks!
Software Test Engineer
kdiver
Perfect .. this is the hiding spot I needed to find ..
