Message 1 of 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I've had a look and can't see this problem anywhere else so I'm hoping someone can help.
I need a rolled plate to be welded on the outside of a vessel.
I have made it in sheet metal using a contour flange, then flattened it to cut around the bits I don't need so it is equal thickness all round. After I have done that, I have no flat sides to use as a stationary reference for when I re-fold so it is currently stuck in the flat pattern.
Does anyone know how to add one without adding or cutting bits away from the part?
Part attached for reference.
Thanks in advance!
