Inventor Forum
roll sheet metal
11 REPLIES 11
Message 1 of 12
974 Views, 11 Replies
roll sheet metal
i want to know some information about how to roll sheet metal by rolling machine i mean calculation formula etc.please help me
roll sheet metal
11 REPLIES 11
Message 2 of 12
JDMather
JDMather
Do you have a Machinery's Handbook?
http://sheetmetal.me/bend-allowance/
http://sheetmetal.me/bend-deduction/
https://www.google.com/?gws_rd=ssl#q=autodesk+inventor+help+sheet++metal
Message 3 of 12
blair
in reply to: JDMather
blair
Here's a couple of utilities:
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
Message 4 of 12
thanks for your help i know about bend allowance and deduction actually  i  have a problem with three roll bending machine, when i want to bend a sheet practically i do it easily with three roll bending machine in shop but when i want to input my data in inventor its confusing because on the sheet i have 3 bendig with different rediuses. how can i measure bend rediuses  on sample when i dont have them ?
Message 5 of 12
JDMather
JDMather
Do you have an image, url or ipt that illustrates your problem?
Message 6 of 12
blair
blair
Not sure about a 3-roll bending machine. There should be a "Calculate k-Factor" function in one of the utilities. You need to work with a pre-measured strip. It should give the details on how to do this in the instructions (should be one of the tabs).
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
Message 7 of 12
i attach the picture i want to bend sheet metal like the sheet back of bucket (red one) how to measure it and please schematically do it in inventor to understand how can i do it tanks.
Message 8 of 12
blair
blair
Picture is missing
Delta Tau Chi ΔΤΧ
Picture is missing
Delta Tau Chi ΔΤΧ
Message 9 of 12
in reply to: blair
sorry
sorry
Message 10 of 12
blair
blair
The k-factor will vary from machine to machine and from bend/forming process to bend/forming process. A proper k-factor is really determined from each process and each machine to acheive an accurate k-factor.
The k-factor is really an approximation of the line length along neutral axis of the bent part. In theory it should be in the middle of the part but different process's will cause it to move slightly from the centerline.
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
Message 11 of 12
blair
blair
The k-factor will vary from machine to machine and from bend/forming process to bend/forming process. A proper k-factor is really determined from each process and each machine to achieve an accurate k-factor.
Delta Tau Chi ΔΤΧ
Delta Tau Chi ΔΤΧ
Message 12 of 12
in reply to: blair
the best answer for 3roll bender mechine calculations is arc formula and the .5 k factor is best astimation for open bends.
