Right mouse button in Browser
Message 1 of 32
I have an issue with right click in browser in assembly mode. The menu need several seconds to appear and when it appear, it automatically do a left click.
Did someone have this problem too?
I have Inventor 2018 with Windows 10.
Replies (31)
Message 2 of 32
JDMather
Are you on 2018 or are you on 2018.1?
Are you using a 3DConnexion Device?  If yes, try Calibrating the device.  (I have seen out-of-calibration device interfering with mouse operation.)
Message 3 of 32
mdavis22569
I've seen quite a few tickets similar to this ...
Mike Davis
Message 4 of 32
mcgyvr
I believe this was solved in one of the updates for 2018..
So please make sure you are fully up to date and try again..
Message 5 of 32
spencer
It's a bug, claimed to be fixed in 2018.1 but is still rearing its ugly head. No word on a time-frame for it to be fixed, only workaround is when using the right mouse button, hold it down until the context/marking menu appears and then you can choose an option without it deciding for you.
Message 6 of 32
I'm on Inventor 2018.1.1.
I use 3Dconnexion device but i don't find calibration option.
Message 7 of 32
bob_holland
Autodesk Support
Autodesk Support
@Anonymous
Welcome back to the Inventor forum.
I have seen this a couple of times lately.
This has usually been resolved by uninstalling your 3D mouse drivers and unplugging your 3D mouse from your computer.
Please try this and let us know that this information resolved your issue.
Thank you.
Bob Holland
Autodesk Product Support
Message 8 of 32
We have this problem at our company.
Did you find a solution?
We have inventor 2018 last update.
Message 9 of 32
Rob67ert
So we are not able to use a 3D mouse anymore?
This must be a joke.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 10 of 32
Hi Bob,
My colleague have the same new computer but he never used any 3D device and he have the same problem. Inventor is unsable with medium and large assembly. Presently, i use my old one and it work properly on Windows 7. My new one is with windows 10.
If you have any idea, please help me. My colleague doesn't have anymore is old computer.
Since last week, my supplier Autodesk supplier try to solve the problem but no result up to date.
Regards
Message 11 of 32
Not yet but if you ever find, please let me know.
Alain
Message 12 of 32
bob_holland
Autodesk Support
Autodesk Support
@Anonymous
The RMC (Right Mouse Click) is a function of your windows drivers.
We have had as of late several customers with this issue and when they uninstalled their 3D Mouse drivers, their 2D mouse started to correctly work after a reboot.
This indicates that the drivers are conflicting and updated drivers I would expect resolve this.
I would start with updating your mouse drivers to see if that resolves the issue.
If you do not have any 3D mouse drivers loaded and are still having this issue, please log in at a NEW windows user profile and see if that resolves the issue.
Thank you all.
Bob Holland
Message 13 of 32
metamere
Everyone at my workplace has been having that issue, even with 2018.1.1, whether we are using 3D mice or not.  It still seems to be present, although slightly less of an issue with 2018.1.2.  As a workaround, you can turn off the marking menu in the View > User Interface menu.
Message 14 of 32
bob_holland
Autodesk Support
Autodesk Support
@Anonymous,
Can you please try @metamere's solution and let us know if this works for you.
Can you let us know if you have customized your Ribbon, Keyboard and/or Marking Menus?
Thank you.
Bob Holland
Message 15 of 32
Rory_M
No customisation here, brand new install with all SPs and it has this problem. It's really really annoying.
Re Spacemouse driver conflicts, I haven't updated mine of late, it worked fine with 2017 for the last year.
I'm using the built in Windows 10 mouse driver, never had to install a manufacturer specific one.
I'll try the workaround that's been posted, hopefully there'll be a proper fix soon.
Message 16 of 32
I have already do this but it doesn't work.
Yes, I have customize ribbon and/or marking menu.
I have also uninstall 3D device.
Message 17 of 32
Hi Bob,
I have tried with another windows user and it resolve the issue.
What must I do for my user name?
Message 18 of 32
Hi Bob,
Message 19 of 32
mcgyvr
@Anonymous wrote:
Hi Bob,
@Anonymous Go to tools..application options and press the export button on the bottom of that dialog to save any application option customizations..
Then close Inventor and find the "Inventor Reset Utility" program included with Inventor and run that..
Then restart Inventor and import your application options and then see if the problem is gone..
Message 20 of 32
philthalmann
I've had the same thing occur many times and thought it was just me and clumsy mousing.. but I don't remember this happening with 2017.
I'm trying your calibrating idea to see if that stops it. Still, strange it hasn't happened in past versions..
