Inventor Forum
Ribs
2 REPLIES 2
251 Views, 2 Replies
Ribs
Can the RIB tool be used on the part (2014) where the sketches are placed?
These will be used for strength or do i have to use Extrusion Tool?
Damian
2 REPLIES 2
CCarreiras
Hi!
You can't use Rib because this tool project the profile in only one linear direction.
In my opinion, i use revolve in the cylinder and extrude (or sweep) in the top.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
in reply to: CCarreiras
Thank you...I thought that would be the case but i check first
Technology Administrators
