Revit interoperability for Inventor 2027
fridtjofZM5ME
Message 1 of 8
fridtjofZM5ME
So I just installed Inventor 2027 yesterday, and the first thing I tried to do was to export an assembly as *.rvt/*.ifc, the dialogue suggests that it will install the neccesary components to do so, I click ok and nothing happens. I click ok again, and I get a message stating that an installation is already ongoing. So I wait. For a long time. Nothing happens. No installation progress bar, nothing to indicate that the process is running or anything.
Shouldn't this just work...?
Replies (7)
Message 2 of 8
89198826955
You need to install the Interoperability package
Message 3 of 8
fridtjofZM5ME
...and where do find that? I didn't see it on the download page for Inventor, it should be under "Extensions".
Message 4 of 8
lauri_barnhart
Hi @fridtjofZM5ME,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Message 5 of 8
ChrisMitchell01
Revit 2027 hasn't been officially released yet which is why you don't see it under extensions yet. The last I saw, the Revit interop component going to be released on April 7th, due to some last minute issues still under investigation.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 6 of 8
SharkDesign
If you select any of the other versions it should install Revit interop for you.
Is there any reason you need 2027? Most building projects are working on much older versions of Revit.
If you need IFC export then you can also do this through Revit 2026 interop.
  Inventor Certified Professional
Message 7 of 8
lauri_barnhart
Hello @fridtjofZM5ME,
It looks like you have received some advice on this thread. Did any of the replies by @ChrisMitchell01 or @SharkDesign answer your question?
If you are still needing more help, please share an update here. The community will be happy to jump in and suggest more steps to help you get where you need to be.
Best,
Message 8 of 8
fridtjofZM5ME
It appears to have been clearified, thank you.
