Revit export failed: 0x8013150d: C:\Program Files\Common Files\Autodesk Shared\Revit Interoperability 2022\Rx\ATFRevitRCEHost.exe
Message 1 of 40
Sorry, can anyone help me, I've updated to a newer version, 2022.1 but it's still issuing the same bug, and the interoperability tool has been installed but it still doesn't work, I tried to open the directory where the error appears like the screenshot below, thank you
Accepted solutions (3)
Replies (39)
Message 2 of 40
johnsonshiue
Hi! The actual fix requires Revit Interop 2022.0.1. Please go to manage.autodesk.com or Autodesk Desktop App to download the hotfix.
Many thanks!
Software Test Engineer
Message 3 of 40
ok thank your sir
Message 4 of 40
I have installed the hotfix, however I am still receiving the same error message. What can I do? Is it a problem if I am using the free trial period for now?
Message 5 of 40
johnsonshiue
Hi Bhumi,
The hotfix should apply to trial also. I am not exactly sure why the hotfix does not work for you. It should. Please uninstall Inventor and all related components (Revit Interop included). Then reinstall Inventor 2022 and apply the hotfix.
Many thanks!
Message 6 of 40
maeshasandewa
ok thank you soo much for all solution sir
Message 7 of 40
Hey, so I uninstalled and made sure all the programs were updated. Yet, I
am still getting the same error.
[image: image.png]
Message 8 of 40
wolfx
Hey, I can't find the "revit interoperability 2022.0.1 hotfix for inventor 2022". Please send it to the email address "wolfx@list.ru"of anyone who has.
Message 9 of 40
johnsonshiue
Hi! It should be there. Please log on to manage.autodesk.com. Scroll down to "Revit Interoperability 2022.0.1 Hotfix for Inventor 2022", released on June 24, 2021.
Many thanks!
Message 10 of 40
wolfx
Hi! There are no updates. Maybe there is some kind of blocking on updates for Russian users?
Message 11 of 40
johnsonshiue
Hi! The update is not under Inventor. It should be called "Revit Interoperability 2022.0.1 hot fix."
Many thanks!
Message 12 of 40
wolfx
Hi. I understand that revit 2022 should be installed and then this update will appear.
Message 13 of 40
johnsonshiue
Hi! I don't believe that is the case. Revit 2022 does not need to be installed on the machine. This hotfix only updates Revit Interop 2022, not Revit as a product.
Many thanks!
Message 14 of 40
wolfx
Hi. Maybe give me a direct link to download this update. After all, I'm not the only one who faced this problem.
Message 15 of 40
johnsonshiue
Hi! The link is in manage.autodesk.com.
Many thanks!
Message 16 of 40
jfreund
I can't find this hotfix ether???and I'm having the same error message
Message 17 of 40
jfreund
I can't find this hotfix?? and I'm having the same error message when trying to export to Revit
Message 18 of 40
johnsonshiue
Hi! What Inventor license do you have? The updates are only available for subscribers.
Many thanks!
Message 19 of 40
jfreund
We subscribe to Revit..we are testing Inventor with a trial. So how can I
test this workflow before purchasing???
Message 20 of 40
dante_claveria
I have the same problem, installed the hotfix and still getting the same message.
