Revision table with 2 rows per entry
 I'm not sure if this is even possible, so I'm asking:
Is it possible to setup a Revision Table that has 2 rows per entry? The idea being the first row has all of the information that is of constant character length per revision (Rev indicator, date, initials), and the 2nd row would be for the description, and could grow in height as needed to accommodate the description.
Is there a way to make this happen in Inventor?
blair
The Description when filled in, will auto-wrap to an additional line, so additional text will propagate to the next new line within the Description box. As far as I can see in the Styles and Standards Editor for the Revision Table, I can't see how this could be done to create a Double Space Line per Row.
The Column Chooser will allow you to custom select the Fields you wish. You will need to add a Custom Field for "Initials".
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
