Revision Table row gap issues
Message 1 of 12
Hi
I am having a strange problem with Inventor's revision table with regards to the heading and row gaps. I created a company template and set up a revision table style in the Style and Standards Editor. The heading gap has been set to a size of 2.25 mm and the row gap to 1.25 mm. Both the row  and heading take a text height of 2.5 mm. This would then sum up to a heading cell height of 7 and a row cell height of 5. This works well and fits in perfectly with the template. See attachment Rev 1. I can save and open this file again and the revision table is correct.
The issue comes in when instead of selecting open I select new and select the template the revision table heading and row gaps are no longer correct as indicated in attachment Rev 2. If I check the gap setting in the Style and Standards Editor they are as per what I initially set up. Has anyone come across this issue?
Mark
Replies (11)
Message 2 of 12
mdavis22569
What version of Inventor?
Also are all of the updates installed?
Mike Davis
Message 3 of 12
INV 2018 all updates have been installed.
Message 4 of 12
mdavis22569
Can you share a templates / idw with this ....
Mike Davis
Message 5 of 12
I save the template as a .dwg not .idw.
Message 6 of 12
johnsonshiue
Hi! Indeed, there was a change in 2017 or 2018 consolidating definitions of drawing tables (hole table, general table, revision table, partslist, and so on). In the past, revision table had its own way of calculating row height and width, which was different than other types of table. It created a lot of confusion.
Unfortunately, due to redefining the row height, legacy revision table in a template file is affected. You will need to adjust the row height (header gap and row gap).
I took a look at your file. The ideal header gap is 1.89mm and row gap is 0.88mm. Please make the change to PC_Rev Table style.
Many thanks!
Software Test Engineer
Message 7 of 12
Hi Johnson.
Thanks for the work around, much appreciated.
Regards
Mark
Message 8 of 12
Hi.. We have had the exact same issue as you mentioned.
Im happy to see a "fix" for this. However my question is, if i apply this change (changing the row gap height) to my Style, wont that then affect all previous drawings we have created since they all read the style too. ??
Message 9 of 12
johnsonshiue
Hi! The change will not affect existing revision tables. It only applies to newly created file and newly created revision table in an old file. For old files, if you do not create new revision rows, the old revision table should stay as is.
Many thanks!
Message 10 of 12
m_scottW4DSR
@johnsonshiue Can you provide a formula for calculating row height?
Message 11 of 12
johnsonshiue
Hi! I am sorry I don't have the formula. The work done back in 2018 was to consolidate the row height compute for all Drawing tables (Hole, Rev, PartsList, General, and so on), instead of individual styles.
If you have an example that does not behave expectedly, please share it here. I can help take a closer look.
Many thanks!
Message 12 of 12
m_scottW4DSR
@johnsonshiue Thanks.
Using iLogic: oTable.rows.item(i).height = 0.5 to set row height to 5mm.
