- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I am having a strange problem with Inventor's revision table with regards to the heading and row gaps. I created a company template and set up a revision table style in the Style and Standards Editor. The heading gap has been set to a size of 2.25 mm and the row gap to 1.25 mm. Both the row and heading take a text height of 2.5 mm. This would then sum up to a heading cell height of 7 and a row cell height of 5. This works well and fits in perfectly with the template. See attachment Rev 1. I can save and open this file again and the revision table is correct.
The issue comes in when instead of selecting open I select new and select the template the revision table heading and row gaps are no longer correct as indicated in attachment Rev 2. If I check the gap setting in the Style and Standards Editor they are as per what I initially set up. Has anyone come across this issue?
Mark
