Revision Table randomly skips numbers
krista.vanderwerff
krista.vanderwerff
Hey all,
Anyone know why the revision table sometimes randomly skips numbers?  I use the "add revision row" feature (either using the button in the revision table: drawing scope, or from right-clicking the revision history in the model tree>add revision row, but it doesn't seem to matter since I see the same behavior both ways), but it just occasionally skips from 1 to 3 or whatever.  In the attached example, it skipped from 8 to 10.  The numbers are not statically overwritten in any way.
It's pretty easy to just change the number manually, but it's mildly irritating (especially if I don't catch that it did it in time), so if it's a setting or something with the template, I'd like to fix it.  I'm using Inventor 2019.
Thanks in advance.
johnsonshiue
Hi Krista,
It is probably a bug. For whatever reason, Inventor thinks #9 was already taken so it was reserved. Does it happen to a newly created drawing or an old drawing. Please share the files here so we can take a closer look.
Many thanks!
Software Test Engineer
lena.talkhina
Hello @krista.vanderwerff  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
