Revision table issues
bwang-tecoustics
Message 1 of 14
bwang-tecoustics
Hi Guys, I got a problem of inventor revision table. As I'm working on revision 2, I changed the drawing's iProperties to revision 2. However, the revision table change the number under revision 1 to 2. See attached pictures. Also, why the row of revision 1 has two blue boxes. What's the meaning of those boxes?
The other question, is there a way to set the revision sort by revision numbers? I have to change it manually every time I insert the revision table.
Replies (13)
Message 2 of 14
mdavis22569
Welcome to the forum ...
what version on are you on ...
You'll want to go into your Revision Editor
RMB on the it and edit Revision style to what you'd like ...set up your sorting etc ...
then adust it to what you want.
the blue means you over wrote what was there generally.
Mike Davis
Message 3 of 14
bwang-tecoustics
Thanks for the quick reply. I am using Inventor 2016. I did set this up in styles (see attached picture). And set the direction, but when I insert it into the drawing, it doesn't follow the setup. If I don't oerwrite the Description, where do I maintain the revision history?
Message 4 of 14
mdavis22569
Make sure you have it set to default ...
If you go into the Manager/Styles and Standards ... Make sure it updated for that drawing.
Also go in the Style Editor and make sure that make sure it's your default.   You can look at the time too under Annotate and see what one using if you have more than one
Mike Davis
Message 5 of 14
mdavis22569
Mike Davis
Message 6 of 14
Try this:
Before changing iProperties, right click on revision table, add new row, then click OK.
Go to your iProperties, summary tab and update the comments field to the text you want in the description.
Go to the status tab, and update the Eng. Approved By: and Eng. Approved Date: fields, then close.
The new revision line will update to the fields you have just changed in the iProperites.
Message 7 of 14
bwang-tecoustics
Thanks John,
The problem is it doesn't update the new revision line, but the old one. It aways update the first row of the revision table, even I have added another revision line per your reply. Any ideas?
Message 8 of 14
Do not use John's suggestion. (Sorry John) You will get what you are seeing. Old revisions change if you use i-properties.
Don't worry about the blue boxes they just mean that something was over-written.
Use Revision I-property for Rev Level only.
Use prompt entries for all your other fields, that way the info will stay with the revision.
I-properties are ties to the file, not the revision level.
Message 9 of 14
bwang-tecoustics
Thanks Doug. Seems this is the only way to do it so far.
Message 10 of 14
We have been using this method for years.
Message 11 of 14
Old revision not changing
Message 12 of 14
John, I'm sorry, I would have not believe it til I saw it.
On Revision A description Does it become a overwritten (blue Square) after Revision B is Applied?
If not them I'm really confused.
Message 13 of 14
bwang-tecoustics
Hi John,
Thanks for the video. Now I know why it didn't work yesterday. What I did yesterday was to double click the revision table and use the icon "Add Row' in the pop up window, which doesn't work properly.
So the coorect way is to right click on the revision table and pick "Add Revision Row". Then the revision number will change to next revision.
Thank you so much.
Message 14 of 14
Rev A will not update once Rev B is added with this method.
You can go back and make the entries static and change them.
