Revision table column width
Hi everyone,
I've a problem setting the width of a column in a revision table inserted in a drawing via VBA.
Below my code
Sub RevisionTable()
    Dim oDrawDoc As DrawingDocument
    Dim oRTBs As RevisionTables
    Dim oLocation As Point2d
    Dim oRTB As RevisionTable
    Dim oRTC As RevisionTableColumn
    Set oDrawDoc = ThisApplication.ActiveDocument
    Set oRTBs = oDrawDoc.ActiveSheet.RevisionTables
    Set oLocation = ThisApplication.TransientGeometry.CreatePoint2d(30.253, 6.035)
    Set oRTB = oRTBs.Add(oLocation)
    oRTB.ShowTitle = False
    oRTB.TableDirection = kBottomUpDirection
    oRTB.RevisionTableColumns.Item(1).Delete
    oRTB.RevisionTableColumns.Item(3).Reposition (2)
    oRTB.RevisionTableColumns.Add (kRevisionTableSheetProperty)
    oRTB.RevisionTableColumns.Item(5).Title = "PROGETTISTA"
    oRTB.RevisionTableColumns.Item(5).Reposition (4)
    For Each oRTC In oRTB.RevisionTableColumns
      oWidth = "1.2"
      oRTC.Width = oWidth
    Next
End Sub
Error reported "Method 'Width' of object 'RevisonTableColumn' failed
Can someone help me?
Thanks.
kennyj
Welcome to the forums!
You might have better results by posting this question in the Inventor Customization forum; where there are a lot of iLogic/VBA/.net wizards lurking.
Good luck!
