Revision table Alpha
GSK2019
GSK2019
Now when you click on the revision table button, the revision table will put the revision index automatically on numeric. Is it possible that when you click on the revision table, that the revision index will be set on Alpha automatically?
Or that you can remove the Numeric function from it? Since my company only works with Alpha, it seems unnecessary to have this option.
CGBenner
@GSK2019
There is no way to remove the option from the dialog.  What you could do is place a revision block on the drawing sheet of your Template, set to Alpha.  Then, when you begin a new drawing it will already be there.  Other than that, maybe there could be some programming option with iLogic?
Chris Benner
