Revision Line Font Size
emailphil04
Message 1 of 8
emailphil04
Hello I'm Phillip.  First time posting here, been using Inventor 2016 for 2 months.  I'm trying to reduce the font size in a revision line.  Just can't seem to find anything that transfers to what's on the drawing.  Screen shot attached, does anybody know how to change this?  Thanks ahead!
-Phil
Replies (7)
Message 2 of 8
Curtis_Waguespack
Hi emailphil04,
It seems like there was a bug with this, but I don't recall for certain. The correct behavior is that as you adjust the size of the text style, the Revision Table row should adjust automatically.
Do you have all of the service packs, etc. loaded for your version of Inventor?
Inventor Products 2016 Downloads
https://knowledge.autodesk.com/support/inventor-products/downloads?release=2016
I hope this helps.
Curtis
Message 3 of 8
emailphil04
Hi Curtis thank you for the reply.  Adjusting size of the text style sounds like a good approach, can you mention how you would go about this?  Maybe I'm doing that wrong..  As for service packs I have no idea how to even check, CAD Administrator handles the software side of things.
Message 4 of 8
Curtis_Waguespack
Hi emailphil04,
Here's a quick video showing how to change the text styles in a Revision Table.
I hope this helps.
Curtis
Message 5 of 8
emailphil04
Oooh thanks so mine doesn't show the Edit Table Styles option when I right-click the table but I got into Styles Editor another way and went into Revision Table category and started guessing which style is active.  Then hit the Pencil symbol next to the Test Style Title.  Not fully comprehending what's happening here but it seems to have changed the text size to .100.  Now I just need to do the same for Title Block (pic attached) although I can start a new topic for that one if needed.  Thanks again Curtis
Message 6 of 8
Sofia.Xanthopoulou
Hi @emailphil04,
don't forget to mark the solution, so other readers can benefit from your exprerience, too Smiley Wink
Continue posting if you still have questions on this topic and please create new threads for new questions.
I hope to see more from you in the community Smiley Happy
Best wishes
Message 7 of 8
emailphil04
Ohh okay got it Thanks Sofia still learning the system 🙂
Message 8 of 8
Sofia.Xanthopoulou
Getting closer @emailphil04Smiley Very Happy
My post was not a solution, just a reminder, so I unmarked it. But if you want to show somebody that you liked the post you could give a Kudo (thumbs up). Everybody is happy about Kudos Smiley Wink
Thank you
