Revision Cloud Hatch
stuart_bassil
stuart_bassil
Has anyone tried to hatch a revision cloud? I can place the revision cloud ok but when I double-click to open it the Hatch Region doesn't do anything. Any ideas?
Gabriel_Watson
If your drawing is saved as DWG format, you can go to AutoCAD and hatch it there if you create a closed loop. The revision cloud output isn't a closed loop apparently.
stuart_bassil
Thanks, I hadn't thought of that. It's a bit long-winded but it is a work-around.
Wynand_Louw_Aranzu
Go to the SDK folder of your Inventor installation, eg. C:\Users\Public\Documents\Autodesk\Inventor 2022\SDK
In this folder there is a UserTools.msi file, run this file and it will extract. You should now have a UserTools folder inside the SDK folder. The UserTools folder contains the DrawingTools add-in. Register this add-in and you will have a revision cloud option in Inventor Drawings.
stuart_bassil
Thanks, Wynand. I could create the revision cloud from the Add-In OK - I just couldn't hatch it.
If I run the 'Close Loop' command on each segment to close it then it can be hatched.
