Frame generator errors occured during inserting Frame Member(s)
p.reig.jane
p.reig.jane
Good morning,
I'm encountering a problem when trying to insert a frame that I recently created. Until now, I did not had any problem when including a frame (mostly aluminium profiles). When I try to insert the recently created one, the error "A frame member could not be created. The reason for the failure is unknown. Please retry." appears.
From that point, I am unable to add any other frame (even those who worked properly at first).
The only workaround is to reinitiate Inventor, and then I can use frame generator with the profiles that until now haven't give me any problem, but again, I am unable to add the recently created frame and when trying to, the error repeats.
There is any fix to this?
Thanks a lot in advance,
Gabriel_Watson
It looks like you're using Inventor 2022.... if you were using Inventor 2021, install the latest updates (2021.1 fixed a similar issue):
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
For Inventor 2020, it was recommended that you used templates that were not migrated, just generated in 2020+. Therefore you could also try generating yours in 2022 format to see if that works:
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Error...
Is this error appearing only when you attempt to add a specific frame size? The content center file for it may be corrupted, which you would need help from your CAD or PDM admin to fix as this article shows:
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Issue...
p.reig.jane
I had Inventor 2021. I've updated it and it seems to work flawless now, had to call and force IT to do so... Thanks a lot!
