Inventor Forum
Revising Common Assemblies.
3 REPLIES 3
chrisbarriedesigns
232 Views, 3 Replies
chrisbarriedesigns
Hi all.
I have a question regarding the use of common parts/assemblies, revising assembly’s and how this all fits together in the model tree and project structures.
I appreciate I have already asked for some help on this topic, but answering one question seems to open up a lot more with this stuff!!
As an example, We are in the process of making 2 off machines made up of 3 weldments - An upper chassis, a lower chassis and a turntable.
Each machine is for a different customer, and is considered a different project, but they are identical in manufacture.
The structure of the machine looks like this.
82000.iam - Chassis Assembly
   - 61000.iam - Upper Chassis
   - 62000.iam - Lower Chassis
   - 63000.iam - Turntable Weldment
The turntable weldment in turn is made up of 3 parts. Like this.
   - 3100.ipt - Slew Ring Plate
   - 3101.ipt - Gusset Plate
   - 3102.ipt - Spacer
During a design review, one of the customers wants to change the turntable weldment to alter the positions of the gusset plates.
The welded positions of gusset plates changes in the assembly, and the weldment gets revised. All the parts within it stay the same.
63000.iam (R1) - Turntable Weldment
   - 3102.ipt - Spacer
As we are making 2 machines, one now needs to use the revised weldment for the customer that has changed his mind, the other needs to use the original weldment for the customer who is happy with the original design. So I’ve got this.
Machine 1 - Original
            - 3102.ipt - Spacer
Machine 2 - New positions
   - 63000.iam (R1) - Turntable Weldment
            - 3102.ipt - Spacer
This now means that the top level of the assembly, the 82000.iam isn’t identical for both machines, because it calls for different revision of the turntable depending on which project/customer is using it.
We are setting up our structure so that any parts, weldments or assembly’s that are used across multiple projects are considered common, they reside in a folder level above our customer specific project folders, as shown below.
C:\\My Projects
My Projects.ipj
  • Bolts and Fixings
  • Common Parts
           01) Assemblies
           02) Weldments
           03) Parts
  • Project 1
           01) GA
           02) Assemblies
           03) Weldments
           04) Parts
  • Project 2
           01) GA
           02) Assemblies
           03) Weldments
           04) Parts
In order for a part, weldment or assembly to “live” in the common parts folder, it needs to be identical in any projects that use it.
However, my 82000.iam assembly and 63000.iam assemblies now aren’t an identical assembly in both projects?
I don’t want to duplicate them in the project specific folders, but don’t know what to do with them to distinguish the difference? Or where they should reside in order to meet the criteria I’m trying to setup.
If they’re different assemblies that are unique to a project, then according to my (self established!) rules, they should reside in the project specific folder. But in this example, just making a small change to the position of the gusset plates potentially means moving all of the parents above it into their project specific folder? Which feels too much?
Any help greatly received as to how others manage this?
Many thanks.
Hi all.
   - 3102.ipt - Spacer
   - 3102.ipt - Spacer
            - 3102.ipt - Spacer
            - 3102.ipt - Spacer
C:\\My Projects
My Projects.ipj
  • Bolts and Fixings
  • Common Parts
           01) Assemblies
           02) Weldments
           03) Parts
  • Project 1
           01) GA
           02) Assemblies
           03) Weldments
           04) Parts
  • Project 2
           01) GA
           02) Assemblies
           03) Weldments
           04) Parts
Many thanks.
3 REPLIES 3
Gabriel_Watson
Try using Model States to see if you can supplement the need for a different assembly. It usually works well if the only change as you mentioned is positioning. Anything more than that, affecting the shape or material, and I would definitely treat each assembly as a different one.
johnsonshiue
Hi Chris,
Gabriel is right. I would try using Model States to manage the variations. Or, you will need different sets of the models (iam and ipt files). Some can be shared among the projects but some cannot be. You will nee to manage that.
Inventor is a distributed design system. Each component has a unique definition (geometry, properties, parameters, appearance, and so on). Whenever there is a need to have a different value (regardless of how many), you will need another file to keep it unique.
Model States sort of break the limitation. For a given set of attributes, each Model State can have different values. You can think of Model State as a mini file within a file. Although it is one ipt file or one iam file, the Model State can represent the model as if you would need to create another ipt or iam file.
Many thanks!
Software Test Engineer
Hi Chris,
Many thanks!
Lucas.dolinarVFXZU
on top of model states, you can also use a flexible subassembly and determine the position in the top assembly.
but i would only do this "one level up" (dont create nested flexible subs)
you can very easily create a ilogic rule that links the constraint in your Turntable Weldment to a value in the top Assembly. This will act similar to a flexible sub (having the dimension in the top level) but will only affect load time when opening the Assembly. Also: it does NOT work if you open both top level assemblies at the same time, but it can be a nice tool for the Model state version ( because now you only need a model state in the top level not in every asm)
