Reverse Engineered Spur Gear
I have two matching spur gears that I'm trying to reverse engineer. No matter what I try I seem to keep getting results from the spur gear generator slightly different than my measurements. I'm also not sure what pressure angle to use.
Here is what I have measured:
Pinion Teeth = 18
Gear Teeth = 69
Pinion Outer Diameter = 1.465in
Gear Outer Diameter = 5.057in
Center Distance = 1.123in (I just meshed the two gears with no clearance and measured the center distance)
I used the following formula to get the diametral pitch (I tried a different formula as well which got 13.92):
Diametral Pitch = (Pinion Teeth + 2)/(Pinion Outer Diameter) = 13.65
If I use the center distance as the design guide, a diametral pitch of 13.65 (not rounding up to 14), a pressure angle of 22.5°, and no unit correction, it gives me a center distance of 3.187in, a pinion outer diameter of 1.465in, and a gear outer diameter of 5.201in.
If I use the unit correction as the design guide, the same diametral pitch and pressure angle, and a center distance of 1.123in, it gives me a pinion outer diameter of 1.457in, a gear outer diameter of 5.074in, and a total unit correction of -0.8169. A little closer, but not quite right still.
No matter what combinations I've tried, I can't seem to get the correct outer diameters and center distance.
I'm also unsure of the pressure angle. The gear preview of 20° looks a little too narrow at the base. It looks like it should be a 25° pressure angle, but the calculations fail at 25° with a "Tool tip is truncated" error. It passes with a 22.5° angle, which looks closer than the 20° angle, although perhaps still a little narrow at the base (it's hard to tell) and a 22.5° pressure angle seems to be an unlikely design.
Any help on where I'm going wrong would be appreciated. I realize that perhaps some of the difference could be in the manufacturing of the gear, so perhaps that is where I am getting it wrong.
Thanks!
