Reusing Frame assembly
I am trying save a copy of a frame assembly and changing only one component but is changes the main assembly too. How do I get around that?
Accepted solutions (3)
brendan.henderson
Doing a Save As on a Frame Assy creates a new Assy file but the frame and the reference skeleton and frame members all stay the same. So changing 1 of the frame members in the new assy will also change the member in the original assy.
Do you have Vault? If yes do a Copy Design and copy all of the files. If no, use the Inventor iLogic Copy Design tool and copy all of the files.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Hi Branden
I don't have vault, but wheat is the proper way to use the inventor iLogic Copy design tool? Josh
brendan.henderson
Brendan Henderson
CAD Manager
Mark.Lancaster
@Anonymous
You may also want to review what @Curtis_W indicated in his reply here.
Mark Lancaster
Curtis_W
Hi JOSHHOFER9049,
Here's a direct link to the information that Mark.Lancaster mentioned:
Use the iLogic Design Copy Tool
It's the same tool that brendan.henderson suggested as well. Scroll down at this link and there is a video:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
I hope this helps.
Curtis
Mark.Lancaster
@Curtis_W
Thanks..  That's why I shouldn't responded to posting late at night..  I remember seeing that posting the other day and it didn't sink in that you first reply was back in 2011...  Smiley Sad   My bad...
Mark Lancaster
