Inventor Forum
restore the ribbon user interface of Inventor
13 REPLIES 13
Message 1 of 14
33048 Views, 13 Replies
Hey all,
I did something following which the view of the inventor has been changed and now I am unable to find get the default outlook/view back.
Below is the user interface I would like to change to default.
Please help me change it as it is quite difficult to cope with.
13 REPLIES 13
Message 2 of 14
CCarreiras
Hi!
Click in the arrow near the "Autodesk 360" tab.
CCarreiras
Message 3 of 14
johnsonshiue
Hi! Do you see the upward arrow button on the menu in far right? Click it a few times to cycle through the layout. Or, you can simply right-clcik on the Ribbon bar -> Ribbon Appearance -> Reset Ribbon.
Thanks!
Software Test Engineer
Message 4 of 14
in reply to: johnsonshiue
does not work for me I would like the default one he is showing as well.
thanks!!!
Message 5 of 14
johnsonshiue
Hi Robert,
Do you mind showing a screenshot of Inventor window? I would like to see what state the ribbon panel is at on your machine.
Many thanks!
Message 6 of 14
JDMather
Double post.
https://forums.autodesk.com/t5/inventor-forum/how-do-i-get-my-default-ribbon-back-in-inventor-2018/t...
Message 7 of 14
I started having the same problem this morning.  I right clicked in the ribbon and tried to change the appearance but it will not change back to normal.  I also tried the drop down arrow next to the A360, and it won't change.
I have rebooted my machine and it didn't help. Any other suggestions?
***UPDATE, I got it fixed, thanks.
Message 8 of 14
mike
We had a similar issue where the Inventor Ribbon was unresponsive to changes from Small, Large, Compact, etc - We had to restart the computer for the Inventor Ribbon to accept changes.
Message 9 of 14
How did you solve it?
Message 10 of 14
Mark.Lancaster
@Anonymous
You might want to give more details about what you're seeing with the Ribbon interface
But I would start here 2018-11-28_6-27-03.jpg by clicking on that button a few times to toggle through the ribbon interface design..
Mark Lancaster
Message 11 of 14
in reply to: Mark.Lancaster
Pretty sure that's the fix.  That button is small and easy to hit by accident and not know.  But that was the answer I needed back when I posted this question.
Thanks Mark!
Message 12 of 14
in reply to: CCarreiras
Well that was easy, just to clarify, there are four options. Repeat clicking until desired view.
Message 13 of 14
lfn.design
Thank you! Helped me a lot
Message 14 of 14
Tlacua2011
Thank you so much!
I was expending a lot of time to restore without success!
Regards....
