Reproducible transitional constraint anomaly
Neil_Cross
Mentor Mentor
Neil_Cross
What the chuffing hell is going on here...
Full steps to reproduce are in this Screencast.
Fast forward to 1:22 to see the issue.  This is 2016 fully patched as of today.
Mark.Lancaster
Neil...  No screencast attached.   Smiley Very Happy
Nevermind...
Mark Lancaster
Neil_Cross
Yah my bad, I rarely use Screencast so I didn't see the big insert button which even on a massive 32" widescreen 1440p monitor is hidden off the bottom of the page Smiley Mad
JDMather
This is a common occurance with surface bodies.
Create one or two half-circle extruded bodies (you might have to experiment with which halves) in the block solid body to use the Transistional Constraint.
Neil_Cross
Yaha obviously it's for a roller chain link, it would have been a lot simpler if I could use the surface and to be fair... there's no reason for it to dance about like that.  Cheers for the confirmation though, oi Autodesk sort it out man!!
