Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Replace text - field text & leader text
Message 1 of 15
I've created a set of "generic" equipment drawings for a client.  Whenever the client has a new piece of equipment fabricated from the drawings they assign it an equipment number (for sake of argument let's say the number is "426").  The generic drawings don't have a number, instead they have a "XXX" wherever the number should be.  Every time they fabricate off of the drawings they revise 100+ drawings to show the equipment number where the X's are.  I am looking for a piece of iLogic code or something that will help me replace the "XXX" with the equipment number so that I don't have to do it manually.
Now before anyone says it, I will: this is a dumb system.  I've tried to convince the client that since the "generic" set of drawings never changes then they should also have a number that never changes.  For some reason the client is not willing to try it this way, they want to continue duplicating and renumbering the drawings for every new piece of equipment.
Any help or ideas would be greatly appreciated.
Replies (14)
Message 2 of 15
I'm no expert but I'll take a stab at this. If you could have this model driven than it is doable. I'll assume for this it is one big assembly. You could open the top level assembly and go manage > bill of materials. In here you could create a custom iproperty, say called job number. This column will be inserted and here is your custom iproperty. You can thus highlight all rows and expand all. With this you could enter a job number and then paste it to every single item in the assembly. This would then have every assembly and part with a custom iproperty job number with whatever your current job number is. You could then have this custom iproperty on all the drawings to be pulled from the part that's inserted. Might take some setting up but you could in the future open the main assembly bom, highlight every "job number" custom iproperty and change them all simultaneously. Then simply run task manager to update drawings. This would accomplish the task you are asking for. Not sure if this is the best way for your scenario but I have used it in the past. Let me know if this helps you
Message 3 of 15
Also you could put the custom iproperty into one drawing and have that setup. You could then use the Drawing Resource Transfer Wizard to apply the new drawing template to all other drawings in one shot versus opening and changing them one by one.
Message 4 of 15
Is it just the drawing number that needs to be updated each time or do you also have numbers within the drawing field as well (as your title alludes to)?
There might be a few ways to do this based on your answers.
iLogic could be one of tham along with Task Manager and maybe even Copy Design in Vault if you have Vault installed.
Message 5 of 15
Come to think of it you could make a custom border that includes the new job number as part of it. Using the tool Drawing Resource Transfer Wizard you could then transfer the border to every drawing. This is a bit of a hack way to do it but the change would stay permanent with the drawing and accomplish your goal.
Message 6 of 15
It is not just the drawing number, it is also leader text and other text/labels.
While some of the suggestions on here are good I am trying to avoid redoing 200+ drawings (each new pieve of equipment may only have 100 or so drawings but there are over 200 in the "generic" set).  I realise that there are/were better ways of creating these drawings but unfortunatley the client was directly involved and is used to using AutoCAD (which has find & replace).  He was also pretty unwilling to bend his thinking.  Made it very difficult to make these drawings "intelligent".  At this point I am just trying to make the best of what we have.
Message 7 of 15
Curtis_W
Hi dschleede,
Here is an iLogic rule that looks at General Notes, Leader Notes, Title Block Field Text, and Sketched Symbols Text and will replace their values when they match the user input search string.
Post back if there are other text items that you need the iLogic rule to search through.
I hope this helps.
Curtis
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oGeneralNotes As GeneralNotes
Dim oGeneralNote As GeneralNote
Dim oSymbol As SketchedSymbol
Dim oSymbols As SketchedSymbols
Dim oTitleBlock As TitleBlock
Dim oTestBox as TextBox
Dim TXT2Find As String
Dim NewTXT As String
'get user input
TXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
'look for blank value
If TXT2Find ="" Then
Return 'exit rule
Else
'Continue rule
End If
NewTXT = InputBox("Enter Text To Replace   '"& TXT2Find _
& "'  with.", "iLogic", "****")
oSheets = oDoc.Sheets
For Each oSheet In oSheets
    Try
    oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
    'look at gerenal notes
    For Each oGeneralNote In oGeneralNotes
        If oGeneralNote.FormattedText = TXT2Find Then
        oGeneralNote.FormattedText = NewTXT
        Else
        End if
    Next
    oLeaderNotes = oSheet.DrawingNotes.LeaderNotes
    For Each oLeaderNote In oLeaderNotes
        If oLeaderNote.FormattedText = TXT2Find Then
        oLeaderNote.FormattedText = NewTXT
        Else
        End if
    Next
    oTitleBlock = oSheet.TitleBlock
    For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
                If oTitleBlock.GetResultText(oTextBox) = TXT2Find  Then
                oTitleBlock.SetPromptResultText(oTextBox, NewTXT )
        Else
        End If
        Next
    oSymbols = oSheet.SketchedSymbols
    'look at sketched symbols
        For Each oSymbol In oSymbols
            For Each oTextBox  In oSymbol.Definition.Sketch.TextBoxes
             If oSymbol.GetResultText(oTextBox)   = TXT2Find Then
             oSymbol.SetPromptResultText (oTextBox, NewTXT)
                Else
            End if
            Next
            Next
            Catch
            'do nothing here,
            'this simply catches errors, for
            'exampl: when a sheet has no title block
            End Try
Next
Message 8 of 15
Curtis_W
****  Updated version ****
The Try/Catch I had in the first version didn't work as intended. Smiley Frustrated
This new version should work as expected, just disregard the previous version. Smiley Embarassed
I should point out also that this iLogic does not handle Sketched Symbols where the static text matches the searched text, as it is only looking at the prompted/field text in the symbols.
I hope this helps.
Curtis
Dim oSheet As Sheet
'get user input
Return 'exit rule
Else
'Continue rule
End If
If NewTXT ="" Then
Return 'exit rule
Else
'Continue rule
End If
	'handle errors
	On Error Resume Next
		Else
		End if
	Next
	'look at leader notes
		Else
		End if
	Next
	'look at title blocks
		Else
		End If
    	Next
    			Else
			End if
    		Next
        Next
Next
Message 9 of 15
I tried your code but it doesn't seem to work.  It didn't replace any of the "XXX"'s with the other number.  Perhaps I am doing something wrong.
Message 10 of 15
Curtis_W
Hi dschleede,
It's possible that you have something in your drawings that are a departure from what I tested. Attached is a sample file that you can look at to see how this is working, and hopefully determine what is different than your file(s). If so you might provide some screen shots of your files to help others better understand what you're working with. But I suspect my example is too simple compared to your real world files.
I hope this helps.
Curtis
Message 11 of 15
It works in your example until you change all of the text so that the XXX's are contained inside other text.
ie:  55XXX-A01
Then it fails.
Message 12 of 15
Maybe this can't be handled with iLogic?  I though maybe it'd be possible to throw a wildcard in there somewhere but I've read that ilogic doesn't support wildcards.
Message 13 of 15
If you are still at a loss with this, I have something similar that I use with my Certification drawings.  Typically a client assigns a Tool number and I have lots of text in my drawings that reference this number (general notes, drawing number, titleblock, etc..) I use the iLogic Form function along with custom iProperties to populate all my text.  So for instance, I open the form, enter the tool number and after applying, the text is filled in with the number at the locations I specified.  It does take a bit to setup (you will have to go through all your text and title block and add in the custom iproperty).  But once finished, it is very simple and effective.  See some screen caps below...
Message 14 of 15
Curtis_W
Update to this to find string that contain the search string as requested in the past:
Sub main
	Dim oSheet As Sheet
	Dim oTextBox as TextBox
	Dim ooTXT2Find As String
	Dim oNewTXT As String
	'get user input
	oTXT2Find = InputBox("Enter Text To Find:", "iLogic", "XXX")
	If oTXT2Find = "" Then
		Return 'exit rule
	End If
	oNewTXT = InputBox("Enter Text To Replace   '" & oTXT2Find _
	& "'  with.", "iLogic", "ZZZ")
	If oNewTXT = "" Then
		Return 'exit rule
	End If
		'handle errors
		'look at General Notes
			oText = oGeneralNote.FormattedText
			oText = ReplaceText(oText, oTXT2Find, oNewTXT)
			oGeneralNote.FormattedText = oText
		Next
			oText = oLeaderNote.FormattedText
			oLeaderNote.FormattedText = oText
		Next
			oText = oTitleBlock.GetResultText(oTextBox)
			oTitleBlock.SetPromptResultText(oTextBox, oText)
		Next
				oText = oSymbol.GetResultText(oTextBox)
				oSymbol.SetPromptResultText(oTextBox, oText)
			Next
		Next
	Next
End Sub
Function ReplaceText(oText As String, oTXT2Find As String, oNewTXT As String)
	If oText = oTXT2Find Or oText.Contains(oTXT2Find) Then
		oText = Replace(oText, oTXT2Find, oNewTXT)
	End If
	Return oText
End Function
Message 15 of 15
yadurajda1
Community Visitor
Community Visitor
Really great!! i was able to replace around 10 to 20 items in seconds!!
But the text in Notes got missed(didn't get replaced). Notes were in different layer.
