Replace standard parameter-table form with the build-in form on Place iLogic Component
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'd like to know if it possible to replace that standard (auto-composed table showing all key parameters) form with one of the build-in iLogic-forms on use of "Place iLogic Component" command?
Please vote for Inventor-Idea Text Search within Option Names
kacper.suchomski
Hi
Yes. Edit the form and change the 3rd edit field from the bottom.
Kacper Suchomski
Maxim-CADman77
Could you please be a bit more precise, what is the name  of the field?
kacper.suchomski
I don't know the English name. In the form properties area there is an entry to enable/disable showing the form when inserting a component.
Kacper Suchomski
Maxim-CADman77
I believe you mean 'Show on Place Component' which is the last of the 'Behavior' (last) section within form properties:
UPDATE:
I've marked this as a solution as well in order to simplify the solution search for those interested.
kacper.suchomski
Yes.
The interface may have been changed during an update. You didn't mention what version you are using.
Kacper Suchomski
