Replace Model Reference-ipt with iam
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all
I see you cannot do a "Replace Model Reference" in an idw by replacing an .ipt with an .iam.
Is there a way of getting around this?
I have a sub assembly of 2 parts.
I have detailed, in idw, the one part.
I have added on, in an iam, the second part.
I want to use the idw of the part, as the layout for the idw of my assembly.
Is this possible, or do I just have to start the idw of the assembly again from scratch?
Mike Kovacik
Inventor Pro 2021 ; Vault Pro 2021
tobias
Hi Mike,
I guess you have to make a new IDW. Otherwise you need to make a simplify part or something to get an ipt of an assembly. In eithercase you probably loose all annotations.
You could add your request to the Idea station but as long it will not take over the annotations you have to start over anyway.
Tobias
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
mluterman
Yeah, I'm doing some drawings from scratch right now because of this. Seems like you should be able to do that.
johnsonshiue
Hi Mike,
This has been requested repeatedly. However, Inventor drawing view object is component specific. A part and an assembly have different options. Replacing a part with an assembly or vice versa will need to destruction of the view. More than likely many things will need to be created from scratch. As a result, this workflow is not offered.
Many thanks!
Software Test Engineer
MikeKovacik4928
Thanks Johnson and everybody else who participated.
Okay, so that is not an option in Inventor.
As you said, too many differences between the part and the assembly would probably lead to
the destruction of a lot of the idw anyway.
In a real world, it is never totally possible to automate everything, as much as one would like to think it is!!
Mike
