Replace and save and replace
dwweekly
dwweekly
Please fix,
To replace or save and replace should keep anything that is flexible still flexible!
I have been burned bad by this little nuance especially when you are 5-6 tree levels (sub assemblies)deep!
this was working in 2022 but lost it in 2023. been meaning to tell you, but too busy trying to fix it when it happens!
Where I work every revision gets a new file, and if you are 5-6 levels deep , each corresponding  sub assembly  gets a new file so we save and replace often.
johnsonshiue
Hi! Many thanks for sharing the issue! I can reproduce it om 2023 and 2024. I will work with the project team to understand it better.
Thanks again!
Software Test Engineer
johnsonshiue
Hi! Just to clarify the issue, this is about Save and Replace command in Productivity tool, right? Have you installed 2023.3 update?
Many thanks!
