What happened to rendering in Inventor? Ten years ago it was possible to create quick renders with photorealistic textures and accurate reflections on flat and curved surfaces. Now everything looks as if it has been sandblasted, whatever adjustments have been made or however long it takes.
The product has made many improvements during this time and my hardware is much more powerful, but the quality of rendering seems to have gone backwards, which means that presenting ideas to clients is poorer. Why?
Paul
HI!
No one can answer that, just say you're completely right. 😖
I miss so much SHOWCASE... Why Autodesk kill this software without giving a satisfactory alternative...
I haven't worked with the old inventor rendering tools. However, I believe the "Lighting and Material Accuracy" setting is what you want to change, maybe anti-aliasing too (Found under Render Image -> Renderer). The Lighting and Material Accuracy setting is what changes the grainy look on my machine. The low quality setting removes the grainy look and the process is much faster.
Hi Jamie
Although I added an image in my email reply, I have tried in vain to show it in this forum!
Hi! Another option is to try the GPU rendering in 2023. In a part or an assembly, go to View -> Visual Style -> Realistic -> enable Ray Tracing. If your machine has a dedicated GPU, it will be rendered using GPU.
Many thanks!
When I look at my last post the images are not viewable, so I am trying again.
