Rendering problems: section view
Message 1 of 10
I try to render an assembly in section view. A few areas are shown correct in the rendered picture. But some are invisible.
Does anyone know how i can fix that?
Thank you for help,
Chris
Replies (9)
Message 2 of 10
Xun.Zhang
Hello @Anonymous,
This is a known problem and addressed by ticket INVGEN-12465 inside.
How about leverage the section view rendering in presentation environment?
Hope it helps!
Xun
Message 3 of 10
I see bolts, elements that are interfering by default. Visuals don't like interfering elements. Does it work if you replace with non-interfering parts ?
Message 4 of 10
No, that doesn't work. In some views you can see through the right inner bearing ring. In other views like here it is visible.
@2@2
Message 5 of 10
@Xun.Zhang wrote:
Hello @Anonymous,
Hope it helps!
Thank you for your answer. What is an presentation eviroment? The different light enviroments which can be choosen?
Message 6 of 10
swalton
The Inventor Presentation environment is another file where you can create animations and/or exploded views to help document your assemblies.
See: http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-F4F6F136-003C-4D1C-9EC1-81102BADC867
Steve Walton
Inventor 2025
Vault Professional 2025
Message 7 of 10
swalton
You might have better luck if you create an assembly-cut feature to get your section view.  That should not have the gap in the surface that you are seeing with the section-view tool.
If you don't want a bunch of assembly cuts in your design assembly, create a "rendering" assembly.  The rendering assembly has your design assembly as its only component.  Define all your cuts, lighting, etc in the rendering assembly and keep your design assembly uncluttered.
Steve Walton
Inventor 2025
Message 8 of 10
Finally i got it.
Thank you a lot.
Message 9 of 10
timdown73
Hello, I'm having the same problem with section views not capping solids in rendered views. Has this issue been fixed yet?
-Tim U.
Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz>Memory: 32.0 GB Ram
Op Sys: Windows 10 professional
Message 10 of 10
johnsonshiue
Hi Tim,
I could be wrong but I vaguely remember a similar issue got fixed in one of the updates. What Inventor release are you on? Have you applied all the applicable updates?
Many thanks!
Software Test Engineer
