- Mute
- Permalink
- Report
Hey,
in a nutshell: I have "clean" files, they do not overelap or even touch each other. So there should be no problem with displaying a normal situation like this.
I have a part in the foreground which is the grey one and a brighter part which is on the back side. But at some random point something odd is happending. You can cleary see this in the finished animation and even in the not "rendered" Inventor window.
For example: Here in this screenshot you can see, all parts are displayed correctly:OK
But if I go further like 2 seconds in my timeline, you can see this:
I know you are thinking "man, there are surfaces touching each other etc." but.. no there are clearly not. The grey one is like 5mm thick and between this one and the brighter part is like 1 mm space.
Somehow (if you need a higher resolution picture, just text me) holes appear that shouldn't be here, too.
Here is also a short gif captured with OBS, I hope that is enouth information for you:
Man this issue is driving me crazy 😄 And I don't know what to do. Maybe a rollback to an older Version? I have done ALOT of rendering and video rendering with Inventor and after using 2020 this comes up at the first try - even with my older parts.
With best regards
Belia
