Render max in Inventor 2021?
jgjYRRKE
Message 1 of 9
jgjYRRKE
Hi all.
I am using Inventor 2020, but would like to render images in higher resolution than 4000*4000 pixel.
Is that possible in Inventor 2021?
Thank you in advance 🙂
Accepted solutions (3)
Replies (8)
Message 2 of 9
johnsonshiue
Hi! I think it should be the same in 2021. Are you seeing an issue?
Many thanks!
Software Test Engineer
Message 3 of 9
leowarren34
Hi @jgjYRRKE,
I've checked both 2019 and 2021 and the limit is 4096x4096 in both versions
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 4 of 9
imajar
Same in fusion 360 and the cloud rendering platform (4096 max)
But 3DS Max can go up to 32,768 x 32,768.  So, if you were willing to use 3DS, you could render a much higher resolution!  (and probably get a nicer looking rendering too).
The other thing you could do is buy an 8K monitor (7,680 by 4,320) and do an interactive ray trace and take a screenshot.  🤔  I think you should do that.
Disclaimer:  I just tried a 32768x32768 render of a simple part in 3DS and my 3DS memory usage went up to 77GB and my computer is not happy about it. . .
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 5 of 9
jgjYRRKE
I find 3DS Max a little hard to use, but renders very impressive images.
If the model contains a lot of parts then i find that adding the right materials take FOREVER.
Starting over with finding materials for an assembly like this would take me a very long time:
Message 6 of 9
jgjYRRKE
No issue.
But I would like to render in higher resolution some times 🙂
Like when I make something for the marketing department at the company i work at.
Message 7 of 9
-niels-
@jgjYRRKE Cool looking machine, would make a nice image for the Friday pictures!
As for rendering with 3DS Max:
SolidAngle provides a somewhat basic material library for Arnold here:
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Material+Library
(download link is the word "here" at the bottom, in the grey bar)
There are some tricks to speed up that process, i'll try to detail it a little here:
When importing your Inventor assembly/part into Max, make sure you have the option to import Inventor materials and assign ID's checked.
When imported, you can then import all the scene materials onto the "Slate Material Editor"
Once that is done, if you right-click on an imported material you have the option to "change material/map type"
You get a list where you can select other materials, so if you've set up a material library then you can select any other pre-made materials. (like the one i linked, or ones you've made yourself)
It probably still needs some tweaking after that, but i hope this makes it a bit more interesting to try Max. 😉
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 9
jgjYRRKE
I will have to try that out, Niels.
If i can bring the materials with me, that will save a lot of time 🙂
Message 9 of 9
-niels-
Arnold can work with the imported Inventor materials, you might have to enable some options to do so.
From my experience though, they don't look as good as Arnold's own materials so it's probably worth changing them.
(i always do, but i like tinkering with the textures and love the control the Arnold materials give me)
Good luck!
Niels van der Veer
The Netherlands
