I am extremely new to Inventor and I'm hoping I didn't just really mess things up. So in advance thank you for your patients with me.
I built a large number of parts and then built an assembly. When building the parts I wasn't considering using a proper naming convention so the parts would be more easily accessible in the future when working on other projects. I read up on how to rename the parts and what I found suggested that I use Design Assistant select the assembly, right click on action and choose rename then right click on name and select change name, select open and then save. I did this for nearly 50 parts. When I opened up Inventor all but a handful of parts in the home screen no longer have an image and if I try to double click them I get a message stating that they can not be found. However, I can still open the assembly but the strange thing is that all of the name changes are reflected within the assembly. I know I have some cleanup to do somewhere but I have no idea where to start or what to do. Any help would be much appreciated.
Josh
