Rename filename using Part Number property
eucci
Message 1 of 22
eucci
Hello All,
My usual workflow is to use INV Pro 2023  & Vault Professional 2023 using a sequential serial numbering scheme.
As I work on a project, I develop a sensible numbering scheme (part number) which is different from the sequential filename.
I have encountered an issue where I need to output to a file (preferrably a stp file) for another team member to import into fusion 360 and they need the parts to import with their part numbers (not filename)
Any ideas on workflow would be greatly appreciated
Replies (21)
Message 2 of 22
dimamazutaMMJ32
Hello
I didn't quite understand the order of saving, so for now I wrote the iLogic code, which converts the file into step format, gives it a name that will is equal to the part number, and saves it to the folder where the original file is located.
Please specify what you need))
Sub Main
    ' Get the STEP translator Add-In.
    Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If oSTEPTranslator Is Nothing Then
	    Exit Sub
    End If
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        oContext.Type = kFileBrowseIOMechanism
		Dim Path As String = ThisDoc.Path
		Dim Name As String = iProperties.Value("Project", "Part Number")
        Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = Path & "\" & Name & ".stp"
        Call oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
    End If
End Sub
Message 3 of 22
b.mccarthy
I use the part number as the filename, as well. I created individual schemas tied to my various clients' needs. Some want a simple scheme. while others prefer a more complex version. Have you looked into that? Vault Data Standard may be worth a look...
Message 4 of 22
eucci
dimamazutaMMJ32
Thank you very much for the quick reply!
If it can work as you describe in the beginning that would be just fine:
*"converts the file into step format, gives it a name that will is equal to
located."*
I'm not familiar with using ilogic code.
I created a new rule from the ilogic tab in the context of my assembly.
I inserted the code that you provided:
*Sub Main ' Get the STEP translator Add-In. Dim oSTEPTranslator As
TranslatorAddIn =
If oSTEPTranslator Is Nothing Then Exit Sub End If Dim oContext As
ThisApplication.TransientObjects.CreateTranslationContext Dim oOptions As
NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap If
oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 -
Configuration Controlled Design ' 3 = AP 214 - Automotive Design
oOptions.Value("ApplicationProtocolType") = 3 oContext.Type =
kFileBrowseIOMechanism Dim Path As String = ThisDoc.Path Dim Name As String
= iProperties.Value("Project", "Part Number") Dim oData As DataMedium =
ThisApplication.TransientObjects.CreateDataMedium oData.FileName = Path &
"\" & Name & ".stp" Call
oOptions, oData) End If End Sub*
When I attempted to save and run it returned the following error
[image: image.png]
Message 5 of 22
dimamazutaMMJ32
Ok
I have attached the .ipt file in which this rule is written.
Note that the file must be saved in any folder.
Checked in 2022 version
Message 6 of 22
b.mccarthy
This is the code I use, and it works as you describe. I set it to fire before save. You might have to rename it.
Message 7 of 22
eucci
Thank you!
Ideally, I'm looking to export the step from the context of an assembly file so that all the parts in tha assembly are saved out to a step file such that the individual bodies maintain the part number property. Will this code do that?
Message 8 of 22
dimamazutaMMJ32
This code translates into a step only the file in which it was run (part or assembly).
In general, it is possible to develop a rule that would export to step all the details contained in the assembly
Message 9 of 22
b.mccarthy
The rule I posted will do this. I tested it on an assembly, opened the step file (Convert Model option), and all of the part numbers came through:
The caveat here is that I have been unable to get it to export component lengths, such as FG assemblies. Anyone have ideas on how to accomplish that?
Message 10 of 22
eucci
dimamazutaMMJ32
I ran this rule from both a part file and an assembly file.
It does save out a step file. However, the step file maintains the former
filenames. It does not appear to create new filenames using the part number
property.
Am I doing something wrong?
Message 11 of 22
dimamazutaMMJ32
I provide the file Assembly1 in which there are two rules
The SaveAs(OnePart) rule converts a part or an entire assembly into 1 step file with a file name that is taken from the part number
The SaveAs(PartsFromAssembly) rule converts parts in an assembly into separate step files with names taken from part numbers in that assembly
Inventor 2022
(view in My Videos)
Message 12 of 22
eucci
Perhaps I'm not running it incorrectly.
I've created a new rule in the assembly file.
Pasted in the code that you posted.
Then I ran the rule and it did export out a step.
When I import the subsequent stp file back into Inventor it does show the part number for the all the filenames in the browser panel nodes. However, when I look at the properties of each part they actually maintain the former filenames and not the updated part number.
This also happens when I import the step into Autocad. It maintains the former filenames for all the undividual bodies.
Maybe I didnt set up the code to run properly?
Message 13 of 22
eucci
THis was sent before seeing your latest. Please disregard. I'll run your latest now
Message 14 of 22
eucci
 THis is getting very close.
Is it possible to export out to one file such that the individual bodies are named based on the part number property?
Message 15 of 22
dimamazutaMMJ32
All the parts were exported as bodies in the assembly.step file, and at the same time, these bodies in the multibody had names corresponding to the part numbers of the original parts?
Sorry, I have to translate into Ukrainian, so there may be a misunderstanding))
Please provide some picture if possible
Message 16 of 22
eucci
Saves all parts of the assembly out to individual files that have the filename updated to the part number property
SaveAs(OnePart)
Saves out to a multibody stp file with the stp filename updated to the part number property
However, the individual parts in the assembly do not have the filename updated to the part number property.
they still have the former filenames
See link below for the files Im using:
https://www.dropbox.com/sh/wjn3rec86m5jd87/AAA3iDH07h7PYdMOOO2pQG5ta?dl=0
Message 17 of 22
dimamazutaMMJ32
Do you want to rename the original .ipt files and have an assembly with these new_named .ipt files? (file name was 182951 and now it must be DER 336CS11)
Is convertation into .stp format Ok for now?
Message 18 of 22
b.mccarthy
Your assembly is missing the CP PARAMETERS 230406.xlsx file.
Message 19 of 22
eucci
I do not need to rename any of the iam or ipt files. I need the bodies in the exported stp file to be named according to the part number property.
Message 20 of 22
eucci
