Hi Group
I have a model that has been made up from a revolved sketch and then had loads of bits done to it etc.. Basically it is a tapered ring with a fillet on the top edge, I need a top face dxf export for profiling and to do this I need to remove the radius on the edge, but because it is a revolved sketch and it is not filleted it is not so easy to do with other references involved.
Is there a way I can temporally rebuild the edge to remove the fillet, I tried in fusion but it won't allow a Zero fillet edge?
I can't upload the sketch to show you unfortunately.
Regards
Adrian
Solved by johnsonshiue. Go to Solution.
Solved by JDMather. Go to Solution.
Well, your problem description makes about Zero sense to me, I'm still not sure if the curve is in the sketch or if it is a Feature Fillet.
But I can think of about half a dozen ways around the problem, but without the file.....
Try Delete Face with the Heal option.
Can't you even post a screen shot
or
create a simple part that exhibits the same problem?
Hi! If I understand your request correctly, it sounds like Delete Face -> Heal mght help. Open the part -> Go to Surface section in the Ribbon -> Delete Face -> pick the filleted faces and check Heal option.
Let me know if it works for you.
Thanks!
Hi Jd and John
thankyou for your input, delete face and heal works brilliantly 8-).
Jd, the reason I was unable to upload the file / jpeg was because it was a customers design file and I had to leave the office for the rest of the day so there was no time to construct an example.
I assumed my description was reasonably clear for the experts and it seems to of worked as the result id perfect 8-)
thanks for your help.
Regard adrian
