Inventor Forum
Removing extra hide lines
3 REPLIES 3
mojtaba77f
568 Views, 3 Replies
Hi
I want have just a part of hide lines in a drawing. how can i removing the others?
hiding one by one hide lines gets too much time.
3 REPLIES 3
johnsonshiue
in reply to: mojtaba77f
Hi Mojitaba,
The description sounds like a file specific behavior. Do you mind elaborating the case? Could you show an example of what hidden lines you are trying to remove?
Many thanks!
Software Test Engineer
kennyj
Hello @mojtaba77f,
One way to do this would be to create a second part that is simplified.  Open the part or assembly, then use the Shrinkwrap command OR use the tools on the "Simplify" tab on the ribbon.
Then, on your drawing sheet, reference this simplified part for any views where you want less hidden lines.  You will still have your correct model for fabrication, reference, etc. but a smaller one to keep from needing to remove a lot of hidden lines.
I hope this helps!
Kenny
JDMather
See Post #10 in this thread about 1:30 into the video (turn on your sound).
