Remove
Remove
Message 1 of 36
Remove
I want to remove ABCDEF only (marked by blue line) but entire AB1234EF area is highlighted when I used extrude tool. How to remove ABCDEF only?
Accepted solutions (3)
Replies (35)
Message 21 of 36
mcgyvr
@Anonymous wrote:
I couldn’t get any clue from Post #2 how to fix the error.
Is it possible to fix the error with rearranging the features in the browser and without tinkering the sketch.
Edit sketch2... Delete the pink dimension (d22).. Press rebuild all.. Errors will then go away..
Message 22 of 36
Post #2 is asking me to combine Extrusion3 and Extrusion4.
Edit sketch2 ???.
It is confusing.
Message 23 of 36
mcgyvr
Edit sketch2 ???.
It is confusing.
Sorry I made a mistake you need to edit Sketch 4 not sketch 2..
Fix Sketch 4.. delete the pink d22 dimension and then press rebuild all and all your errors will be gone.
Blair (post #2) should have said that you could have mirrored Extrusion 3 and Extrusion 4 at one time so you did not have 2 mirror features.
It was only a suggestion though and you do NOT have to do that if you do not want to..
Message 24 of 36
I deleted Mirror1 & 2 from the feature and highlighted Extrusion3 and Extrusion4 to get their mirror image but attempt failed. What is the reason?
Message 25 of 36
JDMather
Click the + symbols to expand the error message.
Message 26 of 36
Which dimension is stumbling block for mirror image?
Message 27 of 36
JDMather
Pink
Message 28 of 36
mcgyvr
As we have already said.. The pink dimension in sketch 4 is the problem..
You MUST fix that first before you attempt to mirror..
Message 29 of 36
JDMather
@mcgyvr wrote:
As we have already said.. ....
Specifically,
Post #2 - the original response. @blair Sketch4 is over constrained, delete the "pink" dimension. This will fix your issue.
Post #21 @mcgyvr Edit sketch2... Delete the pink dimension (d22).. Press rebuild all.. Errors will then go away..
Post #23 @mcgyvr Sorry I made a mistake you need to edit Sketch 4 not sketch 2..
@post #27 @Anonymous  Pink
Message 30 of 36
I have deleted all the lines still error message is coming. Only highlighted sketches have to be mirrored. How can line be a stumbling block for mirror image.
I couldn’t understand logic behind this.
Message 31 of 36
JDMather
@Anonymous wrote:
I have deleted all the lines....
I do not see where anyone mentioned deleting any lines?
I do not see your new file attached?
Are we supposed to guess?
Message 32 of 36
File attached
Message 33 of 36
JDMather
What does an i in a circle mean?
What would you call this thing where the red arrow is pointing?
Would you call that a "Pink Dimension"?  Logic: (It is a dimension, yes/no?  It is the color "pink", yes/no)?
Message 34 of 36
Saying Edit sketch 4 is not enough. What should be done on editing can be a great helpful for a novice.
Message 35 of 36
So far I know constrained dimension is in bracket. Now only I know colour shows over constrained dimension as well.
Why same message but with the different display?
I may be confused Driven Dimension with Constrain Dimension I don't know.
Now mirror image is okay.
Thanks for your explanation.
Message 36 of 36
JDMather
@Anonymous wrote:
1. So far I know constrained dimension is in bracket.
2. Now only I know colour shows over constrained dimension as well.
3. Why same message but different display..
1. No.  That is not correct.  Dimension like this (1.00) is a reference dimension, a driven dimension.
2. Pink color is a "sick" driving dimension.  A driven (reference) and driving dimension is not the same thing.
3. So these are completely different meanings.
A driving dimension controls the model.  (A "sick" (pink) driving dimension cannot control.)
A driven dimension is controlled by the model.  It is for reference only.
