Are there an option to get rid of the OldVersion at all!
Leszek
Leszek
Solved by mcgyvr. Go to Solution.
Yes, thank you. I know it but I don't need the "FOLDER" not to be appeared at all!
Leszek
Leszek
Leszek
Seems the old versions folder will always be created.
What problems is that folder causing for you?
Leszek
I just wanted to know there is hidden option to remove it ....it just bother me. But it is ok. Thank you.
Hi! To get rid of those files, simply right-click on a folder containing Inventor files in File Explorer -> Purge All.
Many thanks!
Many thanks!
Yes I know it too. I would like to be an option for example -2 that AIP doesn't create any backup folders in any case at all.
Leszek
Leszek
