Hi Friends,
As you can see attached picture below to remove extension lines of a center mark I have to select each hole one by one and uncheck the extensions options. I have around 500 to 1000 such holes and it is headache to select each hole one by one. Is there any faster way to do it.
Solved by mikegreslick6607. Go to Solution.
You'll want to edit the Center Mark Style and change the overshoot. This value cannot be zero, but you'll want it as close to 0 as possible.
Not sure if this helps you but...
If you right-click after selecting the Center Mark command you can turn off Extension Lines before placing Center Marks.
Doesn't help if you are using automated Center Lines though...
