Remove diameter symbol (ø) in alternate units in Inventor 2016
We are getting new diameter symbol in the dual dimensions placed in alternate dimensions.
We are facing this issue only in latest inventor releases,after 2014 iteration
Any help would be much appreciated.
johnsonshiue
Hi Sai,
I could be wrong but I don't think there is an option to allow it to happen: primary unit has diameter symbol but alternate unit does not have it. What you could do is to hide the diameter symbol and then edit the dimension and add a diameter symbol in front of the dimension value.
To hide the diameter symbol, you can go to Standard and Styles Editor -> find the active Dimension Style -> Options -> Diameter Dimension -> select the second radio button from the left -> Ok.
Many thanks!
Software Test Engineer
Hi john,
Thanks for your suggestion,I have been using the same tweak
But i am facing the same issue in the latest service pack of 2016.
Earlier in 2014 i wasn't facing this issue.
Can you let me any other way round as a permanent fix
Many thanks
johnsonshiue
Hi Sai,
Indeed, like you mentioned the behavior has been changed in 2016. In 2015 and earlier, diameter symbol only appears in primary unit, not the alternate unit. It was actually a bug, because if the diameter symbol needs to be shown, they need to be available in both units (standard behavior). If they are not needed, they both need to be hidden. So, 2015 and earlier behaviors are wrong. 2016 behavior is correct. Below is a related discussion.
https://forums.autodesk.com/t5/inventor-forum/dimensions-with-alternate-units-diameter-symbol-and-to...
Many thanks!
John,
Thanks for your Support
Hi Dheeraj,
as per my good understanding from the the above tweak from john please try to check and apply the below updates in dim style
i think this would be helpful for you.
please try and let me know the updates.
vp00485110, Thanks for the reply, I have tried your method. But, the option as you mentioned is grayed out See the attached file. We will be getting this option only for features like Hole Callout etc, I think that diameter symbol ø should be present in both the dimensions. As already said it was a bug earlier, which was fixed in latest releases Correct me if I am wrong. Many thanks
