Remove Bom Override
Remove Bom Override
JusticeSmith
Remove Bom Override
JusticeSmith
Is there a way to remove assembly BOM overrides (blue text) on values such as "Part Number" or "Description"? Unlike Parts list overrides, where the "static" checkbox can be unclicked, I see no way to revert changes in the BOM, outside of replacing the affected parts.
  • BOM
Frederick_Law
BOM?  In assembly file?
That's direct edit the part/assembly file.  Permanent change.  Not an override.
Edit part list in drawing is override and can be "turn off" and go back to original.
JusticeSmith
Thanks! I figured that since the text was still blue, then it could be reversed. Appears to not be the case.
