Refine Shaded Drawings
bfoWQH28
Message 1 of 13
bfoWQH28
How to avoid this in the drawings?
PS: this is a very large assembly 6x5 m. This detail is very small (60mm diameter).
Replies (12)
Message 2 of 13
mbochenski93
Hi, i think you should use a higher resolution while exporting to pdf file.
Message 3 of 13
mcgyvr
@bfoWQH28  In the drawing go to tools... document settings..(Drawing Tab) and set "Use Bitmap" to "Offline Only"
Did that help?
Message 4 of 13
bfoWQH28
No, that doesn't help.
Thanks.
For you info, even inside inventor it looks like that:
Message 5 of 13
bfoWQH28
Thanks.
But no, that doesn't help.
Message 6 of 13
mcgyvr
What settings do you have for tools..application options..hardware tab? Tried "Quality"
What about.. Tools..application options..display tab.."Display Quality".. Try "Smoother"
And is "Disable automatic refinement" UNCHECKED on that screen?
Message 7 of 13
johnsonshiue
Hi! How does it look in the assembly document window? Does it look the same? If yes, there are two logical explanation. The geometry may be bad. Open the assembly and go to Manage -> Rebuild All. Does it help?
The other possibility is inadequate graphics RAM or system RAM. Inventor has to reduce graphics fidelity to preserve performance. How much RAM do you have?
Many thanks!
Software Test Engineer
Message 8 of 13
bfoWQH28
Tried "quality", tried "smoother". Didn't work.
I tried wth and wothout "Disable automatic refinement"
In the assembly screen i dont have this problem.
When i say "even inside inventor it looks like that:" i mean in the drawing screen.
Message 9 of 13
bfoWQH28
In the assembly window I don't have this problem.
When I say "even inside inventor it looks like that:" I mean in the drawing screen. Do is definitely not a geometry issue.
I have 8 GB of RAM.
Message 10 of 13
johnsonshiue
Hi! 8GB system RAM or graphics RAM. If it is system RAM, that is below the minimum system requirement. You need at least 16GB or more.
Many thanks!
Message 11 of 13
bfoWQH28
But isn't it weird that it is really well defined on the 3D modeling screen (and other assemblies much bigger and more complex than this one also work really well) and yet Inventor cannot render a good pdf with it?
If I send you the files, can you check if you can export a good pdf?
Message 12 of 13
johnsonshiue
Hi! Sure, please send the files (zipped) to me directly [email protected].
Many thanks!
Message 13 of 13
bfoWQH28
Select a drawing view -> hit Update.
The shaded boundary looks nicer.
