When using an ipn file in a drawing, no data contained in the iProperties of the ipn file populate into the drawing when referenced. The only field that does populate is the file name.
There have been no issues with ipt files and I've tried using different ipn files and idw templates to ensure it wasn't a corrupted file to no avail.
Solved by johnsonshiue. Go to Solution.
Hi Manuel,
This is true that ipn iProperties are not populated to idw. I suspect an iLogic rule can help.
Many thanks!
Hi Johnson,
I didn't realize it would populate from the iam file used in the ipn. I will just update the iam iProperties.
Thank you!
