Hi.
Can anyone help me??
I'm having trouble showing a reference part in an assembly drawing. When said part is set to "reference" it is no longer visible on the drawing. Does anyone know why this could be?
Any help would be greatly appreciated.
Check the view settings. They should look like mine if you want them to appear like normal parts.
Hi.
Thanks for your help and have adjusted my settings but it doesn't seemed to have helped.
Any other suggestions?
Are you sure the visibility of the part is turned on in the assembly?
If the view was created with the visibility of the part off, then turn visibility on and make the view associative.
Hi! Could you post an example of the problem you are seeing here or send the files to me? The behavior does not sound right to me.
Thanks!
It's not possible to show what I am seeing at the moment. The part is visible in the drawing when it is set as a default part but when I change it to reference it disappears from the view.
Is the reference part at some distance from the rest of the parts in the view? Reference parts are not taken into account when calculating the extents of the view, so the view is essentially cropped around the "real" parts. You can adjust this view margin in the Edit View box, Model State tab. The margin shown is what Inventor calculated, but you can increase it in order to pick up reference parts that may be partially or totally left out of the view.
Don't know if that's what's happening in your case, though, since you haven't posted any images or files.
If you want a solution then you need to show us something, otherwise we're just shooting into the dark.
Why can't you show us? If it's confidentiality issues, make up a model and drawing that exhibits the same behaviour.
