Reference dosn't update.
bwang-tecoustics
Message 1 of 13
bwang-tecoustics
Please see attached files. The holes on the HSS is projected from the plate. And the plate is moving with the horizontal angle. The two angles and the HSS are made by FG. I moved the angle by changing the skeleton sketch. The plate moved with the angle but the hole on HSS wou't move. But it doesn't show any problem with the reference either. Every time I open the assembly file, it ask me if I want to update the file. I chose yes and did re-build all. The holes are still not moving.
Replies (12)
Message 2 of 13
solson
I looked at your model.  Somehow the adaptivity seems to not take affect when the cross part projection is made.  I am not sure if the Adaptive setting becomes disabled because the Frame Generator.  I tried recreating it to see if something got changed to make that effect.  The only other possibility is that you have that part adaptive somewhere else already, but I find that unlikely because this is a Frame Generator channel.
A workaround for this would be to link the parameters of the Skeleton to the parameters of the channel with the holes.  When the skeleton is updated, it would push the parameter change to the channel, thereby moving the holes.
Steve Olson
Manager, Training Services
https://knowledge.autodesk.com/profile/O37DF451BDD2485B
https://www.youtube.com/channel/UCgQTCawsuRFJVSHRXIwLdtg
Message 3 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
We are sorry to see that you are having issues with Frame Generator.
How did you create the holes on the HSS?
I am not seeing any hole actions for the HSS.
Thank you.
Bob Holland
Autodesk Product Support
Message 4 of 13
bwang-tecoustics
Thanks for the reply. The holes are make by editing the frame member in the assembly. Select the part, right click and edit. After you edit the frame member, if you open the part file in a new window, you won't be able to see the features. I thought this is how Inventor works as it's always works this way for me. If you want to see the features, you have to select the part in the asembly and edit (or double click the part). The features will show up. I project the hole locations from the other part in this way.
Message 5 of 13
bwang-tecoustics
Hi Solson, when I made the holes on HSS, the center of the holes are projected from the plate with holes. And the projected circle shows the projection symbol. After the skeleton is modified, when I do the prjection again, the projected circle shows a lock symbol, not the projection symbol anymore. Do you know in what condition that will make this happen? As I know if it shows the projection symbol, the projected line should update with the original object, but if it's projected as lock, it won't update later. In my case, it still shows the projection symbol but doesn't update.
Message 6 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
I found that if I did the following it worked:
  1. deleted the holes
  2. recreated the sketch
  3. removing the fixed constraints that are automatically created  (this step is the key)
  4. recreated 11/16 holes
http://autode.sk/1RidLEe
This worked for me.
Please try this and let us know.
Bob Holland
Message 7 of 13
bwang-tecoustics
Thanks for the reply. Did you update the framework assmebly after you change the sketch? I tried but I doesn't work for me. Also, when you delete the constrains on the new sketch, the sketch is not reference to the holes where they projected from. You can also see the sketch is not adaptive anymore. If the holes on the HSS moves with the holes on the plate, that will be really strange to me.
Message 8 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
You will notice in the video that I changed the sketch at the end and the holes moved.
If you follow the steps in the video, does it not work for you?
Thank you.
Bob Holland
Message 9 of 13
bwang-tecoustics
I did follow all youe steps. Can you try change the sketch again and change the height to 50" and see if it works?
Message 10 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
I am not seeing a variable in seleton's sketch named height?
Thank you.
Bob Holland
Message 11 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
I went back into the assembly and made more changes and it is not behaving as expected.
I will need to send this to our development staff for them to take a look at.
I am sorry that you ran into this and thank you for your patience while we work to resolve this.
Bob Holland
Message 12 of 13
bwang-tecoustics
THANKS A LOT FOR YOUR HELP.
Message 13 of 13
bob_holland
Autodesk Support
Autodesk Support
@bwang-tecoustics,
For future reference, you incident ID is: 123174 for this issue.
Thank you again for your patience.
Bob Holland
