Rectangular repeat around an axis
cag198
Observer Observer
cag198
Observer
Observer
Hello experts,
I am trying to achieve the following.
I already drawn the cylinder and the grooves, I also have the first set of holes but can't figure out how to repeat them with a twist.
Any idea?
Thank you
Alexander_Chernikov
First you have to create Spiral curve on cylinder with 3d-Sketch with desired diam, length and rotate angle:
Then create a first Hole on tangent plane to cylinder in first spiral point.
Next use Rectangular patern along spiral, It is important to select Orientation to "Direction1"!
At last use Circular pattern
Example is added in IV2023.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
cag198
Observer
Observer
Thank you very much for the detailed explanation Alexander, I never think of using the 3D sketches.
kacper.suchomski
Since you didn't attach a file, we don't know the real problem. It's possible that you don't need to create sketches, and you can just point existing model edges as the pattern path.
Kacper Suchomski
