Rectangular pattern
Rectangular pattern
SpokenEarth
Message 1 of 12
Rectangular pattern
SpokenEarth
Hi forum, Im trying to create a rectangular pattern for the part TRACK. The last track should have the same distance from the end of the profile as the first track
Can someone be kind to help me out?
Thank you
PS: iam missing due to restrictions for attached files
Replies (11)
Message 2 of 12
admaiora
Can you create and attach  a sample model? (ipt+iam)
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 12
SpokenEarth
Sure,
Message 4 of 12
admaiora
Something like this?
There are more then a way to do that, with different level of difficulty and different level of parametric results.
What do you want to obtain? Just a geometric serie?
Something controlled by the master?
Admaiora
Message 5 of 12
A.K.CORTEL
Message 6 of 12
SpokenEarth
Yes
From the master I want to control only the profile length and the distances between profiles.
From the iam I want to control only the number of tracks respectfully to the length of the profile
Message 7 of 12
admaiora
You can too control the number from the assembly (iLogic)
As you can see your data are in the master part, and the number should be releted someway to these data (length, etc)
Admaiora
Message 8 of 12
blandb
Please see attached video. It can be done with regular patterns.
Hope that helps.
Autodesk Certified Professional
Message 9 of 12
SpokenEarth
Thanks for help admaiora
Message 10 of 12
SpokenEarth
Thank u
Message 11 of 12
admaiora
You are welcome
Admaiora
Message 12 of 12
johnsonshiue
Hi! As Matteo and Brad already showed, it is doable. There are multiple ways to accomplish this. One slight variation to Brad's solution is to use a sketch-driven pattern of a workpoint in the part. Then select the workpoint pattern in the assembly Component Pattern to populate the frame members. The spacing is determined by the sketch and it can be uneven.
Many thanks!
Software Test Engineer
