A lot of users use Inv on dual screens, so this problem must have occurred before, some where.
Changed offices and now have a new dual monitor set-up
Several dialogue boxes etc., had partly disappeared, but because I can see part of them I could drag them to where I needed them.
Frame Generator's dialogue has completely disappeared. I've tried closing the relevant assembly and reference part files and then re-opening them.
I've tried closing and re-starting Inv. I've checked to see whether the FG add-in is loaded and it is.
On the basis that I can't go back to the previous dual screen set-up, how can I get the dialogue box to at least appear in a position from where I can drag it.
I guess, there must be a Registry setting as when Inv is first installed the dialogue boxes are all on the same screen as Inv.
T.I.A
Using Inv Pro 2019.1.2
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Simply by
ALT + SPACEBAR
M Key
LEFT or RIGHT arrow key
Move your mouse and the missing dialog will appear next to your cursor.
Mark Lancaster
& Autodesk Services MarketPlace Provider
