Is there a way to do this when you replace reference geometry in a drawing and they "blow up"?
There are no anchor points to drag to the new geometry like when you create centerlines manually.
Solved by johnsonshiue. Go to Solution.
Hi! Here is an old discussion and an iLogic code to help the situation.
https://forums.autodesk.com/t5/inventor-forum/centerline-unattached-point/td-p/4588223
Many thanks!
