Inventor Forum
Reading parameter
4 REPLIES 4
pbartosinski
602 Views, 4 Replies
Reading parameter
pbartosinski
Hi
Little help please. I would like to read some numeric value parameters and sum it up. I have a assembly which contains parts and sub assemblies. Some od them have parameter "wool". I would like to sum it up and place numeric value to parameter "sum_wool" in main assembly.
Any ideas? Some ilogic?
Reading parameter
Hi
4 REPLIES 4
Xun.Zhang
in reply to: pbartosinski
Xun.Zhang
Hello @pbartosinski,
iLogic code can help without doubt, but if there are not many components with that parameter, then, you can directly Link the component parameter to the top assembly directly as a reference one. After that, just make a new wood_sum to sum up the total value.
Go to top assembly and click Fx, link button and select the component and find the parameter to link.
Hope it helps a little bit.
Xun
Xun
gcoombridge
gcoombridge
If only the parts will have the 'wool' parameter and not the sub-assemblies use this. It will return all parts inside sub-assemblies, just not the sub-assembly itself.
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oOcc As ComponentOccurrence
'parameter called sum_wool already created in parameter box
sum_wool = 0
For Each oOcc In oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
	Try
		sum_wool = sum_wool +  Parameter(oOcc.Name, "wool")
	Catch
		'Do Nothing
	End Try
Next oOcc
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
sum_wool = 0
	Try
	Catch
		'Do Nothing
	End Try
Next oOcc
gcoombridge
gcoombridge
This one if the sub-assembly might have the parameter. Both codes are just adjusted from this blog post: https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html which covers the subject really well
Sub Main SumWoolSub()
	sum_wool =0
     Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    SumWoolSub(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
Private Sub SumWoolSub(Occurrences As ComponentOccurrences, _
                             Level As Integer)
    For Each oOcc In Occurrences
	Try
	Catch
		'Do Nothing
	End Try
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            SumWoolSub(oOcc.SubOccurrences, Level + 1)
    Next
End Sub
	sum_wool =0
End Sub
                             Level As Integer)
	Try
	Catch
		'Do Nothing
	End Try
    Next
End Sub
pbartosinski
in reply to: gcoombridge
pbartosinski
Works perfectly. Thank you!
