Ive moddelled a structure
I firstly need to rotate the whole assembly so that the top becomes the front.
Then it has to be moved in all three directions to fit in with the clients larger model in AutoCAD and I think Navisworks
Johann
Solved by JDMather. Go to Solution.
Mate with offsets to the appropriate assembly origin planes.
Hi! It is possible you just need to redefine the ViewCube orientation. Is the Inventor model correctly oriented against XYZ (regardless of ViewCube)?
Many thanks!
