Re Naming in Design assistant.
cfairfowl
cfairfowl
Hello, when will design assistant give you the option to drag a new name down and populate all cells below with a new name/number but with an increment on the last few digits. Having to rename each cell individually is time consuming.
Sergio.D.Suárez
Excuse me, could you explain a little better what you need? The design assistant is a great tool, but it has some scope. In an assembly of hundreds of parts you must first rename the parts, then assemblies and finally the drawings. When the assembly is too large this becomes tedious and you can make mistakes. There is a tool like ilogic copy that will allow you to go a little further (I personally have never used it). and a third option is to develop a custom routine in ilogic, which creates a new folder, copies the files to this folder, renames them, repairs the dependencies to this new folder
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
johnsonshiue
Hi! I see the request. You would like to rename files sequentially. Here are a few "Rename" related apps on Inventor App store. Please take a look.
https://apps.autodesk.com/INVNTOR/en/List/Search?isAppSearch=True&searchboxstore=INVNTOR&facet=&coll...
Many thanks!
Software Test Engineer
cfairfowl
Thank you, I'll be sure to take a look. Kindest regards. Chris
